GrovePi Case
In Stock
$9.99
This 2-sided acrylic case protects and supports the GrovePi and Raspberry Pi from bumps and drops.  The open design keeps sensors and connections accessible and protected.  The acrylic is held together with steel posts and screws, giving the GrovePi solid protection.
Fits all versions of the Raspberry Pi.
A case for the GrovePi. Protect your GrovePi and Raspberry Pi!
This case protects and supports the GrovePi and Raspberry Pi from bumps and drops.  The open design keeps sensors and connections accessible and protected.  The acrylic is held together with steel posts and screws, giving the GrovePi solid protection.
The GrovePi and the GrovePi Case are both compatible with all versions of the Raspberry Pi.
What’s GrovePi?
The GrovePi is a system that connects over 100 sensors and devices to the Raspberry Pi. GrovePi is an easy-to-use and modular system for hardware hacking with the Raspberry Pi. No need for soldering or breadboards: plug in your sensors and start programming.
Grove is an easy to use collection of more than 100 inexpensive plug-and-play modules that sense and control the physical world. By connecting Grove Sensors to the Raspberry Pi, we empower you Pi to connect to the physical world.
With hundreds of sensors to choose from in the Grove collection, the possibilities for interaction are endless. GrovePi is about integrating Grove modules with the performance and ease of the Raspberry Pi.
More Information
See our GrovePi page for more detailed information on this system!
Loading...
