GrovePi is a hardware system that helps you connect, program, and control sensors to build your own smart devices. It is built to work with all versions of the Raspberry Pi, a very powerful, yet small computer board about the size of a credit card. Learn more about it on the GrovePi product page.
The GrovePi board connects to the Raspberry Pi to the Grove Sensor System and is a Raspberry Pi Internet of Things Kit. The kit allows you to easily connect hundreds of sensors to the Raspberry Pi. Simply connect a cable from the GrovePi to your sensor, download our software examples, and write programs on your Raspberry Pi computer to control and automate any device.
What’s Included in the Starter Kit?
The GrovePi+ Starter Kit gets you up and running with the GrovePi quickly. This Raspberry Pi Internet of Things Kit includes:
- GrovePi Board
- GrovePi Case (2-sided acrylic)
- Case hardware
- Raspberry Pi 3
- Acrylic Sensor Mounts (set of 3)
- Power Supply Wall Adapter (110-240V)
- 6″ Ethernet Cable
- microSD Card, but you’ll need Raspbian for Robots, which you have to download and install yourself
- GrovePi+ Quick Start Guide
- Plastic Storage Box
- Grove – Sound Sensor
- Grove – Temperature and Humidity
- Grove – Light Sensors
- Grove – Relay
- Grove – Button
- Grove – Ultrasonic Sensor
- Grove – Rotary Angle Sensor
- Grove – LCD RGB Backlight
- Grove – Buzzer
- Grove – Red LED
- Grove – Blue LED
- Grove – Green LED
- Sensor Cables
What’s not included, but required?
- Computer, or a monitor, mouse, & keyboard
What else should I know?
- GrovePi works with all versions of the Raspberry Pi.
- If you’re purchasing for a classroom, and want 5 or more, check out our Classroom Kit.
The Raspberry Pi Internet of Things Kit
Connecting sensors to the Internet of Things (IOT) has never been this easy! No need for soldering or breadboards: plug in your Grove sensors and start programming directly. GrovePi+ is an easy-to-use and modular system for hardware hacking with the Raspberry Pi and the Internet of Things.
The GrovePi is a system that connects over 100 Grove sensors and devices to the Raspberry Pi. GrovePi is an easy-to-use and modular system for hardware hacking with the Raspberry Pi. No need for soldering or breadboards: plug in your Grove sensors and start programming. Grove is an easy to use collection of more than 100 inexpensive plug-and-play modules that sense and control the physical world. By connecting Grove Sensors to the Raspberry Pi, we empower you Pi to connect to the physical world. With hundreds of sensors to choose from in the Grove collection, the possibilities for interaction are endless. GrovePi is about integrating Grove sensors and modules with the performance and ease of the Raspberry Pi.
