IMU Sensor for a Raspberry Pi Robot
The IMU (Inertial Measurement Unit) Sensor can be mounted to Dexter Industries robots like the GoPiGo, GrovePi, and BrickPi . It detects motion, orientation, and position of your robot.
The sensor has 9 degrees of freedom (9-DOF) and provides an accurate and high-speed orientation of your robot. The sensor has a built in compass, accelerometer, and gyroscope. You can use these to tell which compass direction your robot is turned to, how fast it is turning, what angle it is to the ground, and how fast it is changing speed.
It comes with a grove cable to plug the sensor into the GoPiGo3, BrickPi, or GrovePi and begin measuring; no soldering required!
Documentation
Check out Python libraries for the IMU sensor here.
Classroom Projects
This sensor can be paired with the Distance Sensor and used by educators to teach advanced math concepts as they turn their BrickPi or GoPiGo into a BalanceBot!
Check out our GoPiGo3 BalanceBot Extension Kit.
