GoPiGo Mars Rover Classroom Kit
Out of Stock
$1,999.99
Make learning about space exploration a fun, hands-on robotics project with our Mars Rover Project for the GoPiGo. The GoPiGo is a robot car that you build and code. The students will design and build a rover to explore and gather data about a newly discovered planet. No prior experience required. View Example Mission here.
Learn more about our Mars Rover Project here.
Make learning about space exploration a fun, hands-on robotics project with our new Mars Rover Classroom Kit for the GoPiGo. The GoPiGo is a robot car that you build and code.
Don’t need 5 kits? Check out the individual Mars Rover Kit.
Objective: The students will design and build a rover to explore and gather data about a newly discovered planet. They will learn to control the GoPiGo with their code and use Distance Sensors, Temperature, Humidity & Pressure Sensors as well as cameras to collect information to analyze and draw conclusions.
This Unit consists of 5 Lessons:
Lesson 1 – Robots in Space: Students will investigate current and past space exploration technology. Based on their understanding of space technology, students will design and build a rover to explore a new planet based on their understanding of current and past Mars rover technologies.
Lesson 2 – Visual Survey of the Planet: Students will investigate the visual properties of a new planet. Students will record observations and inferences based on the data gathered.
Lesson 3 – Living Conditions – Temperature and Humidity: Students will describe properties of planets in the Goldilocks Zone. Students will analyze data about the temperature of planets in our solar system. Students will investigate the temperature of a new planet and compare the temperature readings to that of other planets in our solar system.
Lesson 4 – Energy from Light: Students will investigate and describe solar energy and its uses.
Lesson 5 – Sensing Light on the Planet: Students will design an experiment to answer a question about light on a new planet. Students will present their experiment idea to the class. Students will answer a question about light on the new planet by completing one of the student-designed experiments.
Each Lesson includes the following elements:
  • Background information & resource links (some to share with students & some for teachers)
  • Introductory questions & information to share with the students
  • Step-by-step procedure for the project
  • Student handouts, charts, worksheets
  • Closure exercises
  • Assessment questions
  • Extension
Time Requirement: 8.5-11 hours or class periods
Coding:
  • The Lessons use Bloxter, a beginner drag-and-drop programming language based on Blockly by Google and MIT. It is perfect for beginners, and no prior experience is expected or required.
  • For students with more advanced programming skills, there is room to expand upon the lessons provided to do more sophisticated activities with the sensors as well as data collection and analysis techniques. Students can also use Python, Java, C++ and Node.js to program the GoPiGo robot car, but this curriculum is designed to teach and incorporate Scratch.
Recommended Grades: 5-8
Main Audience: Classroom & After School Programs
Self-Paced? No
What’s included:
This curriculum comes in the form of online lessons through Dexter Studio. If you are interested in using this curriculum school-wide or district-wide, please contact us for that pricing at DexterEd (at) dexterindustries.com.
What else will I need that does not come with this curriculum:
  • A computer with WiFi, an internet connection and a web browser (Chrome preferred, but use Firefox if using touch-screen laptops)
  • A projector is helpful as well
  • Optional: heat lamps, humidifier, dehumidifier
  • Optional: Materials for rover design (construction paper, cardboard, foil, pipe cleaners, recyclables, etc)** This can be a space outside designated as the planet, a different classroom, etc. The students will only get information/data about the space from their rover.
Standards
Unit Standards
VA SOL Science
  • 6.1 — The student will demonstrate an understanding of scientific reasoning, logic, and the nature of science by planning and conducting investigations in which
  1. data are collected, recorded, analyzed, and reported using metric measurements and tools
  1. models and simulations are designed and used to illustrate and explain phenomena and systems
  2. current applications are used to reinforce science concepts.
  • 6.8 — The student will investigate and understand the organization of the solar system and the interactions among the various bodies that comprise it.
Next Generation Science Standards
  • MS-ETS1-1 — Define the criteria and constraints of a design problem with sufficient precision to ensure a successful solution, taking into account relevant scientific principles and potential impacts on people and the natural environment that may limit possible solutions.
  • MS-ETS1-2 — Evaluate competing design solutions using a systematic process to determine how well they meet the criteria and constraints of the problem.
  • MS-ETS1-3 — Analyze data from tests to determine similarities and differences among several design solutions to identify the best characteristics of each that can be combined into a new solution to better meet the criteria for success.
  • MS-ETS1-4 — Develop a model to generate data for iterative testing and modification of a proposed object, tool, or process such that an optimal design can be achieved.
Common Core English
  • CCSS.ELA-LITERACY.SL.6.1 — Engage effectively in a range of collaborative discussions (one-on-one, in groups, and teacher-led) with diverse partners on grade 6 topics, texts, and issues, building on others’ ideas and expressing their own clearly.
  1. Come to discussions prepared, having read or studied required material; explicitly draw on that preparation by referring to evidence on the topic, text, or issue to probe and reflect on ideas under discussion.
  2. Follow rules for collegial discussions, set specific goals and deadlines, and define individual roles as needed.
  3. Pose and respond to specific questions with elaboration and detail by making comments that contribute to the topic, text, or issue under discussion.
  4. Review the key ideas expressed and demonstrate understanding of multiple perspectives through reflection and paraphrasing.
  • CCSS.ELA-LITERACY.RI.6.1 — Cite textual evidence to support analysis of what the text says explicitly as well as inferences drawn from the text.
  • CCSS.ELA-LITERACY.RI.6.2 — Determine a central idea of a text and how it is conveyed through particular details; provide a summary of the text distinct from personal opinions or judgments.
  • CCSS.ELA-LITERACY.RI.6.4 — Determine the meaning of words and phrases as they are used in a text, including figurative, connotative, and technical meanings.
  • CCSS.ELA-LITERACY.RI.6.10 — By the end of the year, read and comprehend literary nonfiction in the grades 6-8 text complexity band proficiently, with scaffolding as needed at the high end of the range.
  • CCSS.ELA-LITERACY.W.6.1 — Write arguments to support claims with clear reasons and relevant evidence.
  1. Introduce claim(s) and organize the reasons and evidence clearly.
  2. Support claim(s) with clear reasons and relevant evidence, using credible sources and demonstrating an understanding of the topic or text.
  3. Use words, phrases, and clauses to clarify the relationships among claim(s) and reasons.
  4. Establish and maintain a formal style.
  5. Provide a concluding statement or section that follows from the argument presented.
  • CCSS.ELA-LITERACY.W.6.2 — Write informative/explanatory texts to examine a topic and convey ideas, concepts, and information through the selection, organization, and analysis of relevant content.
  1. Introduce a topic; organize ideas, concepts, and information, using strategies such as definition, classification, comparison/contrast, and cause/effect; include formatting (e.g., headings), graphics (e.g., charts, tables), and multimedia when useful to aiding comprehension.
  2. Develop the topic with relevant facts, definitions, concrete details, quotations, or other information and examples.
  3. Use appropriate transitions to clarify the relationships among ideas and concepts.
  4. Use precise language and domain-specific vocabulary to inform about or explain the topic.
  5. Establish and maintain a formal style.
  6. Provide a concluding statement or section that follows from the information or explanation presented.
  • (Extension: Lesson 1) CCSS.ELA-LITERACY.W.6.3 — Write narratives to develop real or imagined experiences or events using effective technique, relevant descriptive details, and well-structured event sequences.
  1. Engage and orient the reader by establishing a context and introducing a narrator and/or characters; organize an event sequence that unfolds naturally and logically.
  2. Use narrative techniques, such as dialogue, pacing, and description, to develop experiences, events, and/or characters.
  3. Use a variety of transition words, phrases, and clauses to convey sequence and signal shifts from one time frame or setting to another.
  4. Use precise words and phrases, relevant descriptive details, and sensory language to convey experiences and events.
  5. Provide a conclusion that follows from the narrated experiences or events.
  • CCSS.ELA-LITERACY.SL.7.1 — Engage effectively in a range of collaborative discussions (one-on-one, in groups, and teacher-led) with diverse partners on grade 7 topics, texts, and issues, building on others’ ideas and expressing their own clearly.
  1. Come to discussions prepared, having read or researched material under study; explicitly draw on that preparation by referring to evidence on the topic, text, or issue to probe and reflect on ideas under discussion.
  2. Follow rules for collegial discussions, track progress toward specific goals and deadlines, and define individual roles as needed.
  3. Pose questions that elicit elaboration and respond to others’ questions and comments with relevant observations and ideas that bring the discussion back on topic as needed.
  4. Acknowledge new information expressed by others and, when warranted, modify their own views.
  • CCSS.ELA-LITERACY.RI.7.1 — Cite several pieces of textual evidence to support analysis of what the text says explicitly as well as inferences drawn from the text.
  • CCSS.ELA-LITERACY.RI.7.2 — Determine two or more central ideas in a text and analyze their development over the course of the text; provide an objective summary of the text.
  • CCSS.ELA-LITERACY.RI.7.4 — Determine the meaning of words and phrases as they are used in a text, including figurative, connotative, and technical meanings; analyze the impact of a specific word choice on meaning and tone.
  • CCSS.ELA-LITERACY.RI.7.10 — By the end of the year, read and comprehend literary nonfiction in the grades 6-8 text complexity band proficiently, with scaffolding as needed at the high end of the range.
  • CCSS.ELA-LITERACY.W.7.1 — Write arguments to support claims with clear reasons and relevant evidence.
  1. Introduce claim(s), acknowledge alternate or opposing claims, and organize the reasons and evidence logically.
  2. Support claim(s) with logical reasoning and relevant evidence, using accurate, credible sources and demonstrating an understanding of the topic or text.
  3. Use words, phrases, and clauses to create cohesion and clarify the relationships among claim(s), reasons, and evidence.
  5. Provide a concluding statement or section that follows from and supports the argument presented.
  • CCSS.ELA-LITERACY.W.7.2 — Write informative/explanatory texts to examine a topic and convey ideas, concepts, and information through the selection, organization, and analysis of relevant content.
  1. Introduce a topic clearly, previewing what is to follow; organize ideas, concepts, and information, using strategies such as definition, classification, comparison/contrast, and cause/effect; include formatting (e.g., headings), graphics (e.g., charts, tables), and multimedia when useful to aiding comprehension.
  3. Use appropriate transitions to create cohesion and clarify the relationships among ideas and concepts.
  6. Provide a concluding statement or section that follows from and supports the information or explanation presented.
  • (Extension: Lesson 1) CCSS.ELA-LITERACY.W.7.3 — Write narratives to develop real or imagined experiences or events using effective technique, relevant descriptive details, and well-structured event sequences.
  1. Engage and orient the reader by establishing a context and point of view and introducing a narrator and/or characters; organize an event sequence that unfolds naturally and logically.
  4. Use precise words and phrases, relevant descriptive details, and sensory language to capture the action and convey experiences and events.
  5. Provide a conclusion that follows from and reflects on the narrated experiences or events.
  • CCSS.ELA-LITERACY.SL.8.1 — Engage effectively in a range of collaborative discussions (one-on-one, in groups, and teacher-led) with diverse partners on grade 8 topics, texts, and issues, building on others’ ideas and expressing their own clearly.
  2. Follow rules for collegial discussions and decision-making, track progress toward specific goals and deadlines, and define individual roles as needed.
  3. Pose questions that connect the ideas of several speakers and respond to others’ questions and comments with relevant evidence, observations, and ideas.
  4. Acknowledge new information expressed by others, and, when warranted, qualify or justify their own views in light of the evidence presented.
  • CCSS.ELA-LITERACY.RI.8.1 — Cite the textual evidence that most strongly supports an analysis of what the text says explicitly as well as inferences drawn from the text.
  • CCSS.ELA-LITERACY.RI.8.2 — Determine a central idea of a text and analyze its development over the course of the text, including its relationship to supporting ideas; provide an objective summary of the text.
  • CCSS.ELA-LITERACY.RI.8.4 — Determine the meaning of words and phrases as they are used in a text, including figurative, connotative, and technical meanings; analyze the impact of specific word choices on meaning and tone, including analogies or allusions to other texts.
  • CCSS.ELA-LITERACY.RI.8.10 — By the end of the year, read and comprehend literary nonfiction at the high end of the grades 6-8 text complexity band independently and proficiently.
  • CCSS.ELA-LITERACY.W.8.1 — Write arguments to support claims with clear reasons and relevant evidence
  1. Introduce claim(s), acknowledge and distinguish the claim(s) from alternate or opposing claims, and organize the reasons and evidence logically.
  3. Use words, phrases, and clauses to create cohesion and clarify the relationships among claim(s), counterclaims, reasons, and evidence.
  • CCSS.ELA-LITERACY.W.8.2 — Write informative/explanatory texts to examine a topic and convey ideas, concepts, and information through the selection, organization, and analysis of relevant content.
  1. Introduce a topic clearly, previewing what is to follow; organize ideas, concepts, and information into broader categories; include formatting (e.g., headings), graphics (e.g., charts, tables), and multimedia when useful to aiding comprehension.
  2. Develop the topic with relevant, well-chosen facts, definitions, concrete details, quotations, or other information and examples.
  3. Use appropriate and varied transitions to create cohesion and clarify the relationships among ideas and concepts.
  • (Lesson 1: Extension) CCSS.ELA-LITERACY.W.8.3 — Write narratives to develop real or imagined experiences or events using effective technique, relevant descriptive details, and well-structured event sequences.
  2. Use narrative techniques, such as dialogue, pacing, description, and reflection, to develop experiences, events, and/or characters.
  3. Use a variety of transition words, phrases, and clauses to convey sequence, signal shifts from one time frame or setting to another, and show the relationships among experiences and events.
Common Core Math
  • CCSS.MATH.CONTENT.6.NS.C.7 — Understand ordering and absolute value of rational numbers.
  • CCSS.MATH.CONTENT.6.SP.B.5.C – Giving quantitative measures of center (median and/or mean) and variability (interquartile range and/or mean absolute deviation), as well as describing any overall pattern and any striking deviations from the overall pattern with reference to the context in which the data were gathered.
Loading...
